Slc500
hesham
Jan 2003
cairo
328
Hi All
can any one provide the pin configuration for the programming cable for AB plc -SLC500/03 The processor 1747-l532.
First time Ab
Arik
thanks for reply.
anoher point :is there a communication driver should be installed with the software.
driver will be in rslinx
rslinx - communications - configure drivers
Available driver types: RS232 DF1 devices (add new)
ok
Select comm port & device: SLC CH0/micro/panelview
When all connected - auto configure
beerchug
F
Floating point
Hi all
I am using an analog input card 1747-IB32 in my system when i configure it the PLC automatically generate the input output image for the module .As it's in slot 7 the input image was I7:0 to I7:15
Who can I configure this input image worfs to be in a floating point format?
Soory
Arik
Thank you for reply.
Yes it's not IB32,it's 1746-NI8
Can i use the same data file N8 with thre RTD module 1746-NR8.
When i open the data file N8 it shows to me 4 colums only .i found in it's menu an"extend no. of colums" i inceased it to 24 because i have 24 variable between analog and RTD .Does the above means that iam know have 24 words for my variables.
THX
I dont know about RTD but what I posted is good for NI8(that what I used).
Get the card manual there you can see how to configure the card.
Each card have his own configuration.
BTW it F8 not N8.
When you configure your I\O in I\O configuration use class 3.
Like that.
I hope I helped.
278
can the slc500 5/05 send a email and text over Ethernet ?
191
Hello, did anybody know, if there exist an converting cable like the1492-CM1746-M01 (for an 1746-IB16 to an 5069-IB16), for an 1746-HSCE to an...
395
Customer is buying several spare 504 CPU's to have one handy when there's an issue with the ones in operation. Having them on the shelf for years...
2,852
You have to go offline to create the 'Trend' but do you have to download the program to go back Online with the Trend ?
349
