slc500
hesham
Jan 2003
cairo
328
hi
Does any one the pin configurarion for the cable needed to connect to AB plc type 1746-LA20.
i face one with out program and i need to reprogram it.
I don't have the cable ,is it RS@#@ or DH+.
THX
Hesham,
I assume that you meant to say “1746-L20A” ... many people call this model an “SLC fixed” system ... if this is what you have, then the communication cable you require is ANY ONE of these:
(1) a 1747-PIC adapter to convert your computer’s RS-232 port into DH-485 for the SLC’s communication port ...
(2) a 1747-UIC adapter to convert your computer’s USB port into DH-485 for the SLC’s communication port ...
(3) a 1784-PCM4 cable to connect between your existing 1784-PCMK card and the SLC’s DH-485 communication port ...
so the big question is “what type of port do you have available on your computer?” ...
note that a simple “pinout” will NOT work ... the SLC fixed systems do not have a simple RS-232 communications port ... the signal MUST be converted into DH-485 ...
you can find much more about this subject by researching “1747-PIC” ...
to answer your specific question: if I am correct about your processor’s model number, the SLC’s port is not RS-232 or DH+ ... instead it is DH-485 ...
PS edit ... it looks like Bernie has made the same assumption about your model number ...
correct
Hi
thanks to all,yes your assumtion was right it's 1746-LA20,it was a typing mistake.
I will try to find the recomeended cable from a local supplier.
THX
It's more than a cable
As far as I remember, it's not just a cable, it needs to be a pic unit or a PCMCIA card or a ktx card for your serial port, pcmcia slot or a card for a pci or isa slot in a desktop. These items are readily available from AB but they will cost more than buying a new processor. Last time I checked a ktx and PCMK card were like 1,700 US dollars.
My number may be off but it's not like you can just get a cable from radio shack.
Good luck,
try E-Bay
Marc
259
can the slc500 5/05 send a email and text over Ethernet ?
188
Hello, did anybody know, if there exist an converting cable like the1492-CM1746-M01 (for an 1746-IB16 to an 5069-IB16), for an 1746-HSCE to an...
392
Customer is buying several spare 504 CPU's to have one handy when there's an issue with the ones in operation. Having them on the shelf for years...
2,845
You have to go offline to create the 'Trend' but do you have to download the program to go back Online with the Trend ?
347
