SLC503 Comms to Ethernet/IP or Modbus?
Manglemender
Jul 2007
Lancashire
1,295
One of my customers is interested in extracting some data from a machine running on an SLC503 and they really don't want to change the PLC in any way so upgrading to a 505 would probably not be what they want to do.
Has anyone had any success converting DF1 or DH485 to Ethernet/IP or modbus or something similar in an Ethernet flavour using some sort of adapter?
Best regards,
Nick
Is a small Red Lion HMI or similar out of the question? Df1 From the 5/03 to block transfer and send out ethernet. We do it alot. Cheaper and better than the ENI.
Thanks All,
That Moxa unit looks like it will do the job. I've used other Moxa units in the past so I should have thought to look at them.
Nick
Trying to establish communications between QuickPanel+ IC755CSS12CDB-AA AND Allen Bradley Slc 503 1747-L532 OS301 ser a frn 8 via 9 pin comm port...
28
6,311
Folks, A SLC503 used to be connected to the Internet via a Digi One IAP. During program download to the PLC the Internet connection was...
11,933
I have set up full duplex communications with an SLC503 through a 1747-KE(RS232 to 485 converter) module using the new ABDF1FD full duplex driver...
2,870
what cable and what module do I need to have the powerflex4m drive communication with slc503, I now have 22-scm-232 and 22-RJ45CBL-C20 CABLE, Does...
1,405
Hi, The scenario: The system has been working fine for many years. There is an intermittent issue somewhere. I have yet to look for error...
1,198
