slc503 cpu fault question
aroland
Jul 2016
douglassville
The scenario:
The system has been working fine for many years. There is an intermittent issue somewhere. I have yet to look for error codes.
1) No fault.
2) Pwr down, unplug wired terminal block from NI4 or NO4I card.
3) Pwr up and immediately get flashing FLT on CPU card.
4) Pwr down, plug in TB.
5) Pwr up, no FLT, system works as desired.
Here is my question:
How does the CPU know to give a flashing FLT light when the "wired terminal block" is unplugged from the 1746-NI4 or NO4I card?
(when the wired TB is plugged in the system works as desired.)
Thanks!
Adam
The scenario:
1) No fault.
Thanks!
Adam
What is the fault/fault code?
Analog Input:
Could be a math error(over/under-range scaling) escalating to hard fault.
(ref http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1746-um005_-en-p.pdf PG 6-21)
The multiply operation will generate an overflow bit and minor error
flag whenever the results exceed 16 bits. Since the divide is carried
out on the 32 bit result in the math register, the overflow does not
present a problem. The minor error flag has to be cleared before the
end of the program scan to avoid a system error
Analog Output card:
Does the card detect interrupted OUTPUT current?
Analog Input:
Analog Output card:
I have not been able to get to the system yet to check fault codes. That will be later today.
Thanks for the reference to the manual and verbiage!
I'm looking over the logic now(first time laying my eyes on it). I'll see what rungs etc the I/O is included in and what the logic is....
Thanks!
Adam
Hello, I would like to read and write data between SLC503 and an electronic map. by DeviceNet communication. The DeviceNet communication module...
1,783
Hello, Please , I need help, I want to configure a DeviceNet network. Indeed , my DeviceNet network consists of : 1747 SDN Allen Bradley...
4,778
One of my customers is interested in extracting some data from a machine running on an SLC503 and they really don't want to change the PLC in any...
1,553
what cable and what module do I need to have the powerflex4m drive communication with slc503, I now have 22-scm-232 and 22-RJ45CBL-C20 CABLE, Does...
1,400
It seems like I have asked this before, but I guess I didn’t like the answer ! In RSLogix for a SLC503, I have an exact copy of a program but . ...
1,831
