It seems like I have asked this before, but I guess I didn’t like the answer !
In RSLogix for a SLC503, I have an exact copy of a program but . . . RSLogix doesn’t seem to know that it is the same as the one in the machine. If I do a compare, the highlighted difference in code is only a single rung and it matches exactly. It was probably changed at some point and then changed back instead of cancelling changes. Problem is that I can’t go online and have commented code at the same time.
Also: Many of the data files differ between my commented code version and the running version, otherwise, I would just download my commented version and be golden.
The data files are extensive – of course. What is a good solution to this problem?
Bringing the system down is OK if it is down for less than a few minutes. If I were to download my version and not get the data files correctly redone, that would be bad.
