Slightly off topic: parallel pulse from meter
Ken Moore
May 2004
North, West, South Carolina
3,475
This slightly off topic, but I counldn't think of a better place to ask, so here goes:
I currently have a magnetic flow meter (Rosemount 8732C) that sends a pulse output to a PLC-5 via a 1771-CFM flow meter card. The flow meter doesn't really generate the pulse, it must have an external power source (5-24VDC) that it switches (solid state) on and off to generate the pulse. The meter is located about 1/4 mile from the PLC.
Now the question.
I now need to have the pulse output to the PLC and a local Red Lion Display unit. Has anyone tried this before?
I'm thinking that if I use the same 24 volt source and common, I might be able to have parallel outputs.
I've attached a zipped PDF file with a simple wiring diagram.
thanks,
Ken
The PDF looks reasonable.
Many counter displays don't require a voltage, just dry contacts.
One question. Why not have a separate PLC Output Pulse the Red Lion Counter?
That should work fine. We use CUB5XXXX on a daily basis to do this sort of "sharing." Very rarely when sharing with certain other totalizing devices we may need to add a pull-up/down resistor depending on loads and npn/pnp considerations.
It should work fine the way you have planned, but tying the Red Lion and PLC inputs together MIGHT have an effect. If this is a problem, isolate them using 2 diodes (go away, mrowen!).
One diode between the flowmeter and Red Lion, and one between the flowmeter and PLC.
| Flowmeter DIODE |
+--------] [------+------|>|------> Red Lion <-----+
| DIODE |
+------|>|---------> PLC <-------+
beerchug
-Eric
I don't think it to be a problem either as long as the signal strength is stable.
Eric has a good point.. electrical isolation between receivers is a precaution worth looking at. If one unit fails with input short, then the other should be able to still work.
(mrowan is not far from moron)
bitmore
I'm suffering from a bit of memory loss. About 5 years ago I did a service call on a roof flashing cnc press brake. Among other things that were...
1,805
Does any one have a phone number for Control Techniques technical support? I have a Unidrive SP modular I'd like to tweak but need a couple of...
1,753
I'm in the market for purchasing a USB-Oscilloscope. I am hoping to get some advice from anyone that has any experience with these and can...
1,661
I'm sorry, I know this is off topic. But I figured that this was a good place to get some good advice. I have a new maxitrol regulator (210D...
4,897
Does anyone know of a solid state device that will turn a 24 vdc signal to a one shot pulse of approximately 5ms? I am using this signal to reset...
2,992
