Slightly off topic
Joe Loescher
Mar 2003
Brampton, Ontario
47
Does anyone know of a solid state device that will turn a 24 vdc signal to a one shot pulse of approximately 5ms?
I am using this signal to reset a high speed counter, but it varies with line speed and the card doesn't start counting again until the signal is removed.
Any suggestions?
Thanks Joe
I have used a Banner One Shot amp quite some time ago, do not remember the part no (may be _ _ _ 402). You may browse their site to get the details.
Good Luck
_________
Any suggestions?
Thanks Joe
Sounds like something AB's PICO or Siemens LOGO should be able to do.
Receive an input and use a timer to pulse an output
Ian
Check Newark Electronics. They have dozens of different models that may suit your needs. There are a number of configurable timing relays on the market as well that will meet your needs, configure it to switch on instantly and switch off after a set time. Try IDEC, Omron, Magnecraft brands for starters.
Thanks guys,
I've looked into Omron and Idec but could only find mechanical timers. I need solid state because we run 24/7 and this is fired about 50,000 times a day. The pico may work if it has solid state outputs. I'll look into it in the morning.
Joe
It might be possable to get a .005 one shot from a DL06 using the high speed pulse outputs in Mode 30. Mode 30 is a 7khz stepper outout. So just step by 1 pulse. Never tried it, just a suggestion.
I'm suffering from a bit of memory loss. About 5 years ago I did a service call on a roof flashing cnc press brake. Among other things that were...
1,806
Does any one have a phone number for Control Techniques technical support? I have a Unidrive SP modular I'd like to tweak but need a couple of...
1,754
I'm in the market for purchasing a USB-Oscilloscope. I am hoping to get some advice from anyone that has any experience with these and can...
1,663
I'm sorry, I know this is off topic. But I figured that this was a good place to get some good advice. I have a new maxitrol regulator (210D...
4,899
This slightly off topic, but I counldn't think of a better place to ask, so here goes: I currently have a magnetic flow meter (Rosemount 8732C)...
6,920
