Hello Guys,
I have a question thats not directly related to PLCs, but for those of you who work or have worked in contental Europe (anywhere using 230V as standard single phase AC), I was wondering what 3 phase voltage generally comes into a typical factory directly from the outside lines, and how/where that is stepped down to other voltages, and ultimately to the 230V used for powering outlets, lighter machinery, etc. I'm sure there is no single answer as higher voltage is necessary where heavy machinery is implemented, but maybe a few answers would be good. Is there often times an outside step down transformer near the plant that reduces the voltage to something above 230 used to power heavier duty machines, or is there ever a circumstance where this is actually done with step down Transformers in-plant? Or is it common to just take standard 230V from the local Distribution station? This may be a simple question, but I'd really appreciate an answer to satisfy my curiousity.
Thanks!
Thanks!
