Slope sensor
Kyle Grathwol
Dec 2005
Sandusky, Ohio
129
Good Morning Gentlemen,
Does anyone know of a device that will accurately sense slope and give an analog output based on percent slope? This unit will have to be sealed from the elements as it is on a piece of highway construction equipment and it must be liquid filled to dampen the movement of a pendulum. It needs to read 0-5 degrees in both directions. Any ideas? Thanks for your time.
Take a look at some of the artificial horizon aircraft instruments - they definitely provide an output , though I can't tell you what is is .
Thanks Mordred. I am looking to monitor one axis for example slope from left to right. The link you sent appears to be too sophisticated for this project but I do appreciate your time!!
Hi Kyle,
I think the instrument you're looking for is an 'Inclinometer' which can be as simple as just a potentiometer with a pendulum attached.
Try googling it....
Kevin H
Check with a local distributor for cranes and crane accessories. This type of device is often used to measure and report boom angle.
i have studio 5000 v 24 and the processor is the L75, what i am trying to do is omit the ph controllers we use for waste water treatment. The new...
3,262
Ok guys this isn't a standard how do I use slope for analog. My daughter hates math. She doesn't understand I've tried and tries to explain how...
31
12,136
I am looking for some input on how to proceed with programming some logic in CX-Programmer. The set-up that I am faced with is a calibration...
3,665
I am hoping someone can explain, well actually point me in the correct direction to be able to do the math on an inverse slope. This is was I...
19
6,087
G
I am sure at least one of this site’s brilliant minds can assist me with this… My wife requested I find a program, excel macro, or simply the...
8,404
