Slow response in RSV Studio tag browser
DairyBoy
Jun 2007
UK
393
I've suddenly run into a very slow response to tag browser mouse-clicks in RSVStudio. The version is 11.00 with the latest patches installed.
Curious thing is that a colleague is seeing the same problem (we're working on the same project). So, I thought that it was a corrupt project, but any other PV project covering various PV types gives the same result:
1: Double-click the screen item. Properties popup opens.
2: Click on the tag button. Tag browser opens.
But, on the first instance of a session, where it is necessary to select the offline tag folders, the browser goes non-responsive for up to a minute before allowing a tag to be selected.
Subsequent use of the browser opens the popup with the last used (LH pane) tag selected but still there's a huge delay before the browser responds to any clicks, including e.g. the cancel button.
Has anyone seen this issue?
Thanks.
Interesting: A search for this problem using various terms yielded a host of examples and expletives referring to the ME tag browser, but with only one exception (the reply to which referred to deleting harmony files), no answers. o_O
Shoulda seen that coming... Anyway, tried it; doesn't work. Rockwell doesn't know either.
Hi all, I'm working on a wastewater plant with oxidation ditch aerators. The aerators are on VFDs and the operators want the dissolved oxygen in...
45
17,671
Hi all, i'm having troubles and a slow response on my HMI. For example, i have a macro with an "IF" on differents PLC, and the time to evaluated...
2,184
Imagine a heat exchanger cooling down city water to make ice water and send it all around the factory. On the loop are multiple loads that may or...
1,578
I am upgrading one of our sites from Rsview32 to Factorytalk View SE Local Station on Win10 and I have the program all set up and switched over...
4,154
Normally when writing to the PF525 over ethernet i use the active bit in the stop command as told to do so by many. this is fine for most...
18
3,542
