Small annoying problem with TIE driver help
atifplus
May 2007
Surrey
121
I want to know how to delete the I/O BLock row (marked in red). I have limited space in my chasis so i have to change the modules often and reconfigure TIE driver. The way I do it is deleting the whole device and re create the device with the new I/O config. If there is a way i could just delete the rows in I/O block section that be great
Pic below
Personally do not have a clue but can you right click the 5 and delete row? OR could you have 2 devices and select the one you will be using?
Right clickin on the block of section has no effect. no popup menu or anything even selecting and hitting delete dont work. Just by clickin once (left click) another popup menu comes up which is jsut to input the range value no delete option there either.
I am just foolin the program..
I created different device list and just swaping the IP between the real ip of machine and the arbitrary i created. It is really annoying though. There should be a delete option. Dont know why they made this interface like that agh!!
I know i will be using some new modules soon means lots of different profiles to create .. :( thinkin of using winmacro to get over this pain
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
734
Hi all, I’m new to programming and want to write a simple routine. Push start button, turns on sensor. 2 second delay before anymore logic read...
344
Hi! I'm wondering if PLCs are used for small-scale production. I've got four machines doing different things with textiles, and I'm exploring the...
16
1,356
I am looking at an application where I will need to detect small hairline cracks in stamped metal parts. The sensing will need to be done in the...
1,155
Anyone know what the little green triangle on SCREEN 3 means ? See picture Thanks
471
