Small DC VFD's With Ethernet I/P
Bardac is the only one I know of with Ethernet, but I don't think it's Ethernet/IP protocol, it's their own Ethernet connectivity system. You could ask them though.
On a couple of projects I've been involved with, we changed to using Stepper motors because there are several choices on stepper drives that support E/IP.
Control Techniques to DC Drives with Ethernet/IP as an option, but they are designed for slightly bigger motors. Is there any specific reason for using Ethernet/IP as opposed to getting a small controller from someone like Maxon and controlling it using an analog signal?
For smaller sized motors Beckhoff has some io slice type DC drives that you could attach to an ethernet i/p header
Honestly, by the time you add a new drive and Ethernet module for an existing DC motor this small, you might as well change it to AC, unless it's a special motor or something...
If I was stuck using a DC motor and drive, and had to interface it with Ethernet, I'd just add a Click with an analog output to the existing drive.
Otherwise, I'd use a small AC drive with E-I/P and a new AC motor...
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
735
Hi all, I’m new to programming and want to write a simple routine. Push start button, turns on sensor. 2 second delay before anymore logic read...
344
Hi! I'm wondering if PLCs are used for small-scale production. I've got four machines doing different things with textiles, and I'm exploring the...
16
1,356
I am looking at an application where I will need to detect small hairline cracks in stamped metal parts. The sensing will need to be done in the...
1,155
Anyone know what the little green triangle on SCREEN 3 means ? See picture Thanks
471
