Small I/O blocks for a tight spot??
Nov 2007
Illinois
75
Looking for suggestions for very small remote I/O blocks -- 16 digital input/16 digital outputs. Still waiting on some dimensional specs for some bolts that will be screwed into the tray, but my space is limited to, say 2.5" wide, 3" deep , 6.5 - 7 inches long. Not concerned about the network used (Profibus, E/IP, etc) as I need to find a block that fits first, then work back from there.
I've read about Horner's Smartstix I/O - it seems to fit the bill (or tray:)) so to speak, but I'm not too familiar with them.
Any one have suggestions?
Check http://www.beckhoff.com/english/bus_terminal/overview.htm?id=36483690 for more options.
I've fit the A-B CompactBlock and CompactBlock LDX into places that small, in the channel on the side of conveyors. DeviceNet, A-B RIO, and Profibus-DP.
Hi looking to install a smaller less sophisticated PLC for fountain timing and also one analog pressure sensor which would be used to detect...
23
636
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
820
Hi all, I’m new to programming and want to write a simple routine. Push start button, turns on sensor. 2 second delay before anymore logic read...
372
Hi! I'm wondering if PLCs are used for small-scale production. I've got four machines doing different things with textiles, and I'm exploring the...
16
1,436
I am looking at an application where I will need to detect small hairline cracks in stamped metal parts. The sensing will need to be done in the...
1,212
