small Safety IO module for Ethernet/IP
JeffKiper
Jun 2006
Indiana
2,462
Im looking for a small safety IO block.
OEM has PB stations with
(1) 2 channel Emergency Stop PB with light
(2) 1 channel standard PB with light
(1) PNP input for a sensor. (Prox, photoeye, limit, etc.)
(1) 5 watt solenoid
I'm looking at putting them in a PB pedestal and running the field IO put of this with M12. Everything I find has a large footprint and doesnt like to share standard IO with Safety IO.
Turck has a Hybrid block that I have used and it worked well. Im looking for a compact version. Have any of you all seen a small footprint block? IP 67 or20 is OK. it will be in an enclosure. Ethernet /IP to an AB safety PLC.
Yes 1734 point is our standard. It is just to big to add in a small PB box for an OEM. The price point is a little high for a single PB station. If I had a higher density of IO they would be great. We are trying to keep the foorprint small.
A 4 hole,PB box with 4 DQ for IO, Ethernet , power
Has anyone ran across a CIP safety IO module that isnt AB? I have a customer that needs 4 inputs 3 outputs and 2 safety inputs (emergency stop...
912
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
734
Hi all, I’m new to programming and want to write a simple routine. Push start button, turns on sensor. 2 second delay before anymore logic read...
344
Hi! I'm wondering if PLCs are used for small-scale production. I've got four machines doing different things with textiles, and I'm exploring the...
1,356
I am looking at an application where I will need to detect small hairline cracks in stamped metal parts. The sensing will need to be done in the...
1,155
