Small Skid System
Roy Matson
Apr 2004
Vancouver
465
We often construct small skids for clients doing research.
I have often used Opto22 for these skids
Sometimes we use Labview running on a PC
The budget doesn't allow for proper PLCs such as AB
Since we are starting a couple of new projects I thought it might be a good idea to look at other small scale Lab scale systems.
Any suggestions for
Inexpensive hardware
Inexpensive software with no licence fee
Floating point Maths
Easy access to historical data e.g. CSV format
Suitable to install in Class 1 Div 2 environment.
Roy
Roy have a look at arduino, all software is free, and open source.
one board complete is about 25 $
it works with labview
one drawback is it is running on 5 volts, so you will need some optocouplers etc.
and yes beckhoff i like too, however they do cost.
the software is free (codesys) and this can be used via C into this arduino.
I'm surprised no-one mentioned Automation Direct.
I have never used one but I see several posts on here about them.
Which models do floating point math?
I visited the Beckhoff website bur found it user unfriendly, that doesn't bode well IMHO
Roy
Look at IDEC Pentra models. I have had great luck with them. Better pricing than most Automation Direct products. Faster processing than many plcs's and very flexible (no back plane needed).
Ken
Hi looking to install a smaller less sophisticated PLC for fountain timing and also one analog pressure sensor which would be used to detect...
23
639
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
820
Hi all, I’m new to programming and want to write a simple routine. Push start button, turns on sensor. 2 second delay before anymore logic read...
372
Hi! I'm wondering if PLCs are used for small-scale production. I've got four machines doing different things with textiles, and I'm exploring the...
16
1,439
I am looking at an application where I will need to detect small hairline cracks in stamped metal parts. The sensing will need to be done in the...
1,214
