Small test probes
boneless
Feb 2008
OKC
1,628
Hi all!
We use the 2-channel Phoenix relays. These have a couple of small holes at each connection, presumably for test probes.
Anyone have any recommendations for probes that would work here? The holes are very small. I tried spitting on my probe, but it still won't get in....
Crocodile clip probes on my meter an use them to hold some straightened out paperclips.
Has got me out a a pinch once or twice. Especially testing voltages at D pin connectors.
Although the post above is a more professional, permanent solution.
the testprobes can only have 60 Volts. I use a piece of cable with correct diameter and i soldered simple clips on the other side.
Thanks all!
Turns out, someone had a set of the Fluke TP88 laying around. These work great for most of our applications(24VDC).
Will check out some of the other proposals. Thanks so much! :)
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
733
Hi all, I’m new to programming and want to write a simple routine. Push start button, turns on sensor. 2 second delay before anymore logic read...
344
Hi! I'm wondering if PLCs are used for small-scale production. I've got four machines doing different things with textiles, and I'm exploring the...
1,356
I am looking at an application where I will need to detect small hairline cracks in stamped metal parts. The sensing will need to be done in the...
1,155
Anyone know what the little green triangle on SCREEN 3 means ? See picture Thanks
471
