Smart Guard 600 Mode not automatically Executing
mikefo99
Dec 2020
canada
Hello, we have a smart guard 600 controller, every time we have a power loss to the system, upon start up we have to connect with our laptops and change the mode in parameters to execute from idle... In parameters it's selected to automatically execute upon start up.. we have other machines using the same controllers/systems and they automatically function upon re initiating power, it will not hold when execute is selected, everything runs fine until a power loss. I have tried replacing the unit with new and downloaded the existing parameters and even tried downloading and older set of parameters with no success.... The PLC used is a CompactLogix, can't seem to figure out what happened a long the way or if something had been changed... Thanks
It's been a long time since I used one of these, but I've got a vague memory that if the safety isn't "locked" it will ignore the automatic execution selection. Are all your devices safety locked?
Hi, The other day I was trying to connect to a smartguard 600 safety controller using the USB port on the front of the controller. For some...
4,630
Thanks in advance for your help. I have to present information about our Safety Systems (Emergency Stop, Light Curtain, ...) on a HMI. As...
2,352
I have a problem with Smart Guard 600(1752-L24BBBE) I am able assign an IP address for the device use BOOTP Server, but I can not disable the...
2,483
Hi looking to install a smaller less sophisticated PLC for fountain timing and also one analog pressure sensor which would be used to detect...
23
628
hi all i am new here i have a mitsubishi smart touch hmi i.e ms-60t-pe but i cannot find a software to edit and download a program in it any help...
188
