Smart hose system
VJTX
Oct 2007
TEXAS
126
I am working on a smart hose system. It will have 12 hoses that can connect to one of 36 sources. I will pulse the 12 outputs one at a time (on the hose) , read the inputs, to determine where that hose is connected. Is there a clever way to do this? I am using micrologix 1400.
The hose system isn't too smart yet.
Please describe in much more detail what each output controls. What exactly are the inputs?
Maybe with this information we may be able to help.
The output is just to multiplex. Output one on hose 1 will connect to one of 36 inputs, depending on which manifold inlet it is connected to. For example: out1----->>input 7 ; out2---->>input 1....
I am thinking of turning on out1 for a say 1 sec. , read the inputs, since only the input that is being fed by the output will be on, then put that number into n7:20 (which would be 128 for bit 7 on); pulse out2, read the inputs, put that number into n7:21(2 for bit 1), etc. until I get to out12, then start over. Speed is not required, its to know which hose( to the press) is connected to which silo.
A couple of simple solutions comes to mind.
Use an SQO triggered by a timer.
Use a CTU triggered by a timer and a series of compares on the value of the ACC.
Yeah, I think I will just ADD 1 to B3:3 and then do the equates, using free running clock to increment.
hi all i am new here i have a mitsubishi smart touch hmi i.e ms-60t-pe but i cannot find a software to edit and download a program in it any help...
172
I HAVE SMART TOUCH MS-60T-Pe MITSUBISHI HMI BUT I CANT FIND A SOFTWARE TO EDITE AND DOWNLOAD A PROGRAM IN IT.......CAN ANYONE HELP PLEASE!
79
Hi guys, I am looking for a good replacement for an Omron smart relay. A customer of ours has a couple of these and they are beginning to fail. As...
1,153
Hi all, I have existing S7 200 smart PLC system, I don't know what software version they used to program it. I use microwin smart version 2.3 to...
513
Hi I am fresh for Siemens. I have Smart 700 ie v3 HMI and I need the software to download/upload or configuration. How can I get the software...
644
