SmartGuard 600 IP adress change
alexbeatle
Feb 2010
San Francisco
188
Hello,
Has anyone had trouble changing IP address of the existing SmartGuard 600 1752-l24bbbe?
See attached.
Tried plugging in directly and through an unmanaged Ethernet switch.
Thank you.
JPEG_20180530_075003_7024493650901601703.jpg JPEG_20180530_075047_6221870536961195174.jpg
Not with that device specifically, but your problem is most likely that something, most likely a PLC, is actively communicating with the device and won't let you change settings. Unplug the device from the network, power cycle it, and plug directly in with your laptop and try again
Unfortunately, this did not help. Same error
It's been 3+ years since I used last time, but as far as I remember SmartGuard needs to be unlocked before you can do it. I recall that in require Safety Device reset.
Also I remember that it's very picky with valid IP addresses and masks. Specifically in your case, Gateway address is illegal, you can't use .0 because it's reserved for the network address with this specific subnet mask.
I did try to unlock the safety. Put it in idle. Disconnect the DeviceNET cable. Reset. Still same error.
I even tried to just change the original IP adress from .134 to .135. Same error
Safety reset does not reset IP. See attached.
IP address has nothing to do with this. The Gateway address is illegal.
If you need gateway then set it to the valid number for your gateway or leave it at 0.0.0.0
As for reset, you need to put all check boxes.
Please allow me to rephrase. I have the IP setup already and it works. While ultimately I want to change the IP, Subnet and Gateway, I am not even able to change a single digit in the working IP setup. My network switch is unmanaged.
I still stand by my answer that gateway is wrong.
I would save the program, wipe it out completely and start over
we have Smartguard 600 controllers using device net, they work fine until a power disruption, when this happens, we have to connect via RSNetWrox...
1,517
RSNetworx for DeviceNet v11.0 RSLinx 3.71 Our electrical designer is using a 1752-L24BBBE SmartGuard 600 Controller to control a project's cell...
4,261
Hi, Does anyone know how to add comments to remote safety IO on the the smartguard 600 controller. I have 1791DS series remote IO but cant work...
3,385
Hi I am new here and have a few questions for people that have used SmartGuard 600 system. at where i work we are in the process of upgrading our...
1,770
I have a process that we are installing an AB SmartGuard 600 Safety PLC on. I am trying to give the Safety PLC its IP address and I cannot get it...
6,084
