SMC Flex. Line loss parameter
said-art
Jan 2017
Aksai
Dear all
We have 8 motor controllers, all of them have the same trouble. Though the parameter #84 enabled "Line Fault Disable" there is no any faulty signals when cutting incomming voltage. It means controller does not detect line loss when incoming cuircuit breaker is off. It seems like that protection is inactive.
I would appreciate if you had any ideas.
Artur
I need to purchase a few Large soft starters for our plant and we prefer to stay Rockwell. We have purchased SMC Flex 150 in the past and they...
273
Hi, I want to start 150 SMC Flex from Studio 5000. I have the AOP and P SMC flex AOI imported in my program. I have also set the logic mask to...
343
Hi there, very much new to AB Drives / Drives in general. Driving a pump with SMC Flex Drive Rating: Pump (5-135) Revision 6.008. Currently the...
2,174
Dear experts, I have encountered an SMC Flex (361A,480V) wired for 3-wire where that if you press 'Start' Then immediatly press 'stop' it will...
1,797
Hey guys We have an smc flex that faulted. Fault 14. Went through the troubleshooting guide ended up swapping the connections on the back of the...
1,664
