Issue is I have been provided with a A-B typical for an SMC-Flex, with no parameters beyond the fact that it states that I need to change the Logical Mask (Param 87) to 44, all DPI ports enabled. I have managed to figure out many of the parameters I require but unfortunatelly it has power (after disconnect) to Option Input #1 (terminal 16), Hand position to terminal 17 (Start Input) and Auto position to terminals 18 (Stop Input) and terminal 15 (Option Input #2). I am at a loss of how this will work, I can see it working in Hand, because the Stop input is not powered and the start input is powered, but when in auto,I have a Stop, and an input, but I don't know what parameters to program to make this work.
any helps works
any helps works
