Software for designing sequences
You are fully right - there is an open Linux available. Unfortunately, I have no experience programming the controller with Python etc., but only with CODESYS. Anyway, with CODESYS it works fine :p
Did you use the 'vanilla' brand - or the Wago version, and if so what version?
Say as an example I want to program Mfr. Part No. 750-882
What would I choose from the following:
Software
Stock-No. MPN Description
667-9255 759-302 Software WAGO I/O Check 2
882-0338 759-302/000-923 Software WAGO I/O CHECK 2 and USB Kit
509-6090 759-333 Programming Tool IEC 61131-3 WAGO I/O PR
I strongly suggest Smart Draw https://www.smartdraw.com/
Its the best for making any kind of diagram and has a plethora of templates already made to download for almost anything you want to do.
I use it for all kinds of diagrams and to produce machine documentation.
Download and try it on the full-featured trial. I guarantee you won't be disappointed.
Not the original question but if I have the choice of standard Codesys and manufacturer version I would always use vanilla.. Why.. I have used IFM controllers with Codesys works good but then you see that they doesn't support symbol configuration.. Not easy to use other brand of HMI.. Used Epec controller with Codesys.. that one didn't use Codesys standard functions for Can open... I hope that Codesys like Android forces manufacturers to support a minimum set of functions otherwise Codesys gets a bad name when it's really not Codesys fault..
123
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
123
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
111
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
124
Hi everyone, I am an omron plc tec , lately I came across a siemens s7 200 cn plc . Can someone help me regarding the software required and...
26
649
