Software for Jetter Nano-C?
strantor
Sep 2010
katy tx
401
I am confronted with an aged German machine containing Jetter Nano-C PLC and Jetter DIMA3 Servo drive. In the manuals I found online it mentions the software and it appears to be a MS-DOS program. I have reached out to Jetter as well as the OEM of the equipment, neither seems to deem my query worthy of reply so I will ask here.
1. Will the current Jetter PLC programming software support the older PLCs? If so, which software?
2. If not, where can I obtain the old MS-DOS software? Must I pay for this? How much?
3. Is it possible to upload the program from this PLC or must I have the original source files?
4. Has anyone even heard of this brand of PLC?
To answer your questions in reverse order:
4. Yes, they were used in some semiconductor equipment from Singapore I worked on 15-20 years ago.
3. No you need the source files. There is also no online edit option.
2. The software was called SymPas and was free. I found this link - https://www.jetter.de/en/downloads/software/classics/sympas.html
1. I don't know.
The programming language was Pascal like and the program itself was made up of a maximum of 32 tasks running simultaneously(ish). At the time I always found Jetter to be quick to respond and very helpful, but that was along time ago.
1. I don't know.
Thank you! Very helpful. I searched the website for the software but did not find it, you get 10 points for this.
135
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
124
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
113
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
124
Hi everyone, I am an omron plc tec , lately I came across a siemens s7 200 cn plc . Can someone help me regarding the software required and...
26
650
