Solar panel power
Thanks, There will be no battery and the inverter I had in mind was not grid tied (that's why the contactor; to switch between inverter and grid) I might go with a grid tied now much better.
Inverter should have a low DC bus voltage trip. I guess you could use AC output as control voltage for the switching relay. Downside of doing this may be rapid back and forth switching.
Think I would use a separate DC volt sense with a timer on it to prevent back and forth cycling.
Dan Bentler
If you're going to use a Mastervolt Inverter, you don't need a relay at all. If the DC voltage is to low, it will switch off, and will use nearly no power. If the DC power is high enough it will start to deliver to the grid. There are no external components needed.
In my case I've placed a manual breaker in de DC line, but this depends on the max. voltage on the DC bus, and is just for maintenace usage.
Don't use a Chineese inverter in small Solar systems, as these are much less efficient at low or no Solar Power.
Jack
Happy Monday to everyone, I have posted a few post lately regarding Click PLC, Soil Moisture Probe and Cell Modems. Now I am trying to power...
3,153
Hey All, I have never researched Solar Panels except for reading about them here and there. I have a customer who wants to install two panels on...
4,909
Our plant has a network repeater station located in a field with two ProSoft RLX2-IHG network radios for connecting our plant network to a well...
2,417
good evening i have been given the task of get solar power for my facility. Well I have a lot to learn. can anyone tell me a good website to use...
22
8,456
I have an application were I need to collect one or two data points at a remote location (ie 1/8 to 1/4 mi) from my building. I can get the data...
1,739
