SirCharles1
Good day Gentlemen. I have a pneumatic valve manifold (MAC 92 Series) and I am having some difficulty getting it to operate as it should. I have air going into the manifold that is about 80 psi and I have 24 volts activating the valve. I believe it is activated because there is an LED on top of the valve that is lit, and the solenoid makes a small clicking noise. The air does not seem to change its path (from port a to port b). Please see the attached pictures. I thought this would be quite a simple device to get working. Apparently not. Thank you for considering my problem. I do appreciate it.
