Solid State Relays
Jon R
Jan 2007
Tadley
206
I am thinking of using SSRs rather than normal relays on some PLC outputs to switch hydraulic solenoids that are rated at 30W/24Vdc, due to the better life of the SSR as this system will be used very frequently. The hirschmann connectors for the solenoids also have a supression circuit built in.
Not used SSRs before so looking for a bit of guidance on this.
Our panels are mostly built using Telemecanique parts and I have found the ABS 2SC02EB in their catalogue. Has anybody used these before, and what are they like?
Jon.
Very reliable - have used them for many years without a single failure.
I've found solid state relays in general are extremely reliable in the power range you are talking about. The two brands I have used most are Omron and Weidmuller, so consider those as well if you have a supplier.
We always use MURR Electronik ones, they are DIN Rail mounting and only 6mm wide... we often have a relay bank with SPCO relays and SSR's at the end.
Think they are only about £8 each but well worth the added cost!
Also dont forget you can always fit a reverse biasing diode to smooth out the arking effect on the relay contacts, very usefull on high DC current applications such as brakes and valves etc.
Good Evening , I should know more about Solid State Relays . I have a system with 8) 120 vac Vibrators . These Solid State Relays have...
24
2,059
Hi! Hopefully I'm allowed to ask this question here, if not the admin is free to delete it. We have a standard cabinet we ship to our customers...
20
5,472
Hello, I have been reading online about optocouplers and solid state relays; I think I seem to have some misconception about their functions. From...
3,390
What are the pros and cons of using stepper motor driver over SSRs in running a typical stepper motor? Thanks! =))
3,248
Hello all. I have what may be considered a stupid question, but hey, at least I'm asking before trying it blindly, so here we go... I am feeding...
4,382
