Solving a problem through PLC
Ppride
Mar 2009
ca
The problem:
Break is released and one second later my motor starts functioning.
My motor stops functioning when it reaches a certain value.
One second later my break is applied!
How many functions do I have there? How do I start off?
What starts the sequence?
What inputs do you have? What PLC are you using?
A little more info may get you the help you desire. Tell us or show us what you have come up with so far.
People on this forum are willing to help, but you must do some groundwork first. You have made a start by describing the sequence, now look at how you are going to control it with inputs and outputs.
Jon.
I am using a GE fanuc series 90-30. My input is an analog current
At this point I really want to know to use a timer. I looked at the different kinds an I belive TMR_tenths is what i need.
I am not sure how it would be applied. for one seconds I realize PV would be 10. but what does ?????? in the middle mean? Do i need to register an input?
Is this related to your other post?
If so what is giving the analogue signal?
Unfotunatley I don't know anything about the GE software but normally something would have to start the timer. If you have some code already then post as a jpeg or PDF.
Correction
Hi to all reading this, My questions are.... 1) does any1 follow the PLC approach as seen by the Ron Beaufort YouTube videos 2) where can I obtain...
2,502
I'm working on a system where a machine grabs a part and moves it in relation to a fixed welder head. The machine consists of two arms that grab...
5,214
Hi! I suppose want to do my degree project, can anyone give any suggestion about project base on PLC.. thank you.. ;)
1,805
Hello automation masters Iam in business trip in France at the moment and this customer case forced me to write down following The plant I am...
30
7,244
Hi, It happen often that there one condition of a or-box changes for a real short time ? What do you dp if it's to fast to see ?
3,782
