SoMachine ethernet connection problems, PC to plc
ChanceGuy
Aug 2014
WA
Hi, I'm trying to connect my PC to my plc via ethernet and am having no luck.
SoMachine V4.2
TM251Mese controller with updated firmware.
I am plugged straight into the PLC from my pc via ethernet cable. I have tried both ethernet 1 and 2 on the PLC although I understand ethernet 1 is the preferred connection.
I can login to the PLC via the usb cable just fine. I used that to update the IP and subnet mask of the PLC.
The PLC is set currently fixed.
10.10.19.230
255.255.0.0
no gateway
I have my pc ip address fixed as well.
10.10.19.229
255.255.0.0
no gateway.
I can see the controller from the SoMachine controller screen and even ping it over ethernet, just can't login.
https://ibb.co/iXFDVd
iXFDVd
I have tried other ip addresses as well as every subnet mask(255.255.255.0 and 255.0.0.0) on both the PC and PLC. I have my wi fi disabled as well so that only my wired connection is active.
I'm currently out of ideas on what to do. I can't access my drives when connected via USB and want to be able to use a ethernet connection to log in when in the field.
Problem was solved. Had to get in to the Schneider Gateway management console and direct the LAN to the current IP address i had programmed into the computer. It was still stuck on an old IP not being used.
Does anyone have experience or documentation on how to add a Generic Ethernet IP device in SoMachine V4.1 SP2 or in the latest version of codesys?
2,514
Hello Everybody Anybody knows where I can get this version of SoMachine? The new machine expert version won't open my project saying there is a...
43
I am trying to connect with a Schneider plc which has a firmware version only available in Somachine v4.2. In Machine expert After taking upload...
116
Hello dear experts, I incurred in an anomaly while working with HMISCU devices by Schneider. I downloaded the program and everything seems to...
453
Configuring a PWM block for servo control in SoMachine today and was attempting to run in simulator to test some loop controls, will PWM output...
934
