Some TCP/IP questions i need help with
arcurifisher
Apr 2011
Ohio
A ___
A ____ is defined as the end-point in the conversation, which can be a client interface in executable or Web script form,or a programmed automaton called a bot (short for robot).
a.
dispatch server
c.
notification server
b.
principal
d.
switchboard server
The piece of software that accesses DNS name servers on behalf of the network client is called a(n) ____.
a.
name resolver
c.
primary master
b.
subdomain
d.
caching server
When one DNS server receives a recursive request, that DNS server issues what are called ____ to the name servers in its hierarchy, or to servers provided as pointers in reply to earlier iterative requests, until an answer is received
a.
recursive queries
c.
domain queries
b.
address queries
d.
iterative queries
By default, ____ queries the default name server specified in the current machine’s TCP/IP configuration.
a.
NSLOOKUP
c.
multi-homed
b.
mail exchange
d.
IP
Well, you get points for brazenness. Most students that want help with their homework around here at least try to hide the fact a little bit.
Yeah, ok. Show your work. What have you done to figure this out?(Use the google!) We can help w/ the more difficult ones, but yeah.. not doing everything for you..
Hello Long time lurker. I am flailing around trying to figure out how to implement MODBUS TCP on a W2000 IPC that controls one of my company's...
5,888
Hello everyone! I'm currently trying to connect a Quickpanel+ to 3 different GE relays. The problem are the drivers and how to communicate over...
2,063
Hello all, I've been reading a lot to try to get up to speed with my first PLC project. I'm having some trouble establishing communication...
4,515
Hi All. Hope you can help. I have spent all day on this and still nowhere. 🔨 I am using Automation Direct (Host Eng) ECOM module on a...
4,281
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
166
