sorting out registers on AB 1500
deanpavil
Oct 2016
Coorado
I am fairly new to this and I am trying to find out how this works. I have a setup using a Allen Bradley 1500 that is operating as the master. A Red Lion HMI is connected to the PLC on the RS232 port. There is another device that is communicating RS485 to the HMI. There are several 16 bit holding registers from that device that the PLC is taking in and doing some math then displaying on the HMI. The values get put in the F8 Float data table and then a multiplier is used and this new value is sent to an Integer table. That value is sent to the HMI. I can see how the values of these registers are modified in the PLC but I don't know how the original bits are selected or sorted to be placed in a particular Float register. I wish to add and or change some of these registers from the RS485 device to look at some different data. Thank you
Most likely, the Red Lion HMI is controlling communications. Download Crimson software from Red Lion's website and use it to extract the program from the HMI. Then look at the tag database to see how a memory location in the RS485 device is passed through the HMI to the PLC.
I have worked on small projects using AB Micrologix but now we want to take a photo, process it online, and sort based on returned variables...
324
Hi, I have just started with WinCC unified (v17) and there are alot of things I used on Comfort but now are not available. Currently I am finding...
2,834
I'm trying to be smart about naming my tags so things automatically group together alphabetically, but for some reason it doesn't work like I...
3,642
Hello friends. There is an int type, number that I got from the DataBlock. For example, the DataBlock address is Db1.dbw0. Here's what I want to...
32
10,445
Good afternoon all, I am working on a college project where we have to sort 3 different color legos. Orange, Black, and Tan. I am using a color...
30
6,770
