If I have my PLC output driving a SPDT relay, is there any downside for that relay to control both directional solenoids on a hydraulic valve connected to a cylinder?
Specifically, could the immediate switching have detrimental effects on the relay, solenoid, or valve? should I use one relay for each solenoid with a short delay between? if so, why?
I could use a single solenoid with a spring return but I'm working with existing config.
Thanks in advance
Thanks in advance
