Special Memory S7 1200
Nov 2011
Ireland
182
Hello
One more quick question. I am using FB to program my PLC. On the first FB "EN" pin on the left hand side of the FBD I currently have a switch wired in with a constant logic 1 so that the FB's in series are Enabled.
is there any way of specify a logic 1 constantly instead of having to wire a 1 signal. I have tried typing "True" on the EN but the plc wont accept it. From using a S7 200 I remember there was a contact called "SM" something that always closed when the PLC was put into run mode. I cannot remember the exact address if anyone can tell me it would be useful
thanks
Check the hardware properties of the CPU and enable the system bits and clock, you get to set the address of the always on and off bits as well as the clock byte.
On the S7-200 you had to have a contact before instructions with an enable input, you don't need that with the S7-1200. Connect the enable directly to the left hand supply bar. If you do need 'always on' or special timer bits like the S7-200 had then as Mike_RH go in to 'Device Configuration' and set some M memory to be used for System and Clock memory.
I am actually using Function block Programming (to try it out and i think it suits my program better) therefore there is no left hand supply bar (as far as i can see). I am not using Ladder programming so i dont believe i have a left hand side bar
I am kind of old fashioned and never got round to that new fangled Function Block Diagram stuff. As Mike_RH said, go in to the properties for the PLC and enable System and Clock memory, you will get a bit just like SM0.0 only you get to choose the memory addresses to use.
Yep got that problem sorted last week. program is working fine only for the performance of the HSC. Still working on trying to improve the measurment
thanks
Hi, I'm modifying a PLC program from a Hitachi H200 PLC. I have only the upload. To make the program readable i'm applying symbols to the...
3,354
Good Morning , We have some new machinery coming in with a ControlLogix 5582ES Safety CPU . I would like to update our software before the...
2,459
We have an inductive sensor mounted in front of a rotating pulley, which has one small steel part rising close to the sensor. The sensor is wired...
2,228
Hi!! Could someone please help me find a special relay command (not a real relay) that stays activated when it receives a pulse from a NO contact...
3,416
