Speed And Torque Control In Siemens Mm440
RAJATPALLAV
Jul 2007
BHOPAL - INDIA
34
Dear All !!
We are going to use Micromaster MM440 for puller application in Extrusion process.
Problem is how to changeover from speed control in one direction to torque control in the reverse direction ???
Torque control is available if P1500 is programmed. What is significance of P1071 , P1072 , P1075 , P1076 ???
I'm doing my first wind/unwind project, and I need some input from someone with more experience. ...I'm getting my butt kicked trying to control...
38
11,374
Hi, We want to buy a linear actuator 24VDC. We want to control this with a circuit board fro electromen...
2,313
We will use a S120 drive for wheight compensation. The drive has to give extra force on a wheigt that is attached to cables. Problem now is, if...
3,772
We have an application where we use a motor with encoder to provide torque at low speeds (+- 5 Hz). The drive is Sinamics G120 in closed loop...
3,276
We wish to use Siemens MM440 in extrusion application, where motor works in torque control mode in one direction and speed control mode in reverse...
5,295
