S120 torque control : limit speed
Plc_User
Dec 2005
Belgium
317
We will use a S120 drive for wheight compensation.
The drive has to give extra force on a wheigt that is attached to cables.
Problem now is, if the cables would brake the weight would completely fall, becaus also the torque of the drive is in down direction. We want to assure now that the wheigt can only fall at a reduced speed controlled by the drive. In the function plan 6640 of S120 I see there is speed limiting for torque control, but because of the falling wheight the torques should be opposite to the normal applied torque.
Will the speed limiting function in torque control be able to reverse automatically its direction if the maximum speed limit is hit?
What does the speed limit function in torque control do exactly : only reduction of speed of control,
can it also generate torque opposite to the setpoint?
Hi all, I am having a machine with old 802d sl siemens controller. I am trying to tune servo by Siemens starter software. Anyone experienced...
69
Kindly, has anyone tried to control Lenze servomotors with Siemens S120 drives ? Any special hints ? Have some concerns for the resolver and servo...
236
Hello to all, I have a STEP 7 project (v5.6) with S7-400F CPU and Sinamics S120 drives with CU320x2PN (ord. nr. 6SL3 040-1MA01-0Axx). I need to...
945
We have several S120 1FK7 axis controlled by an S7-1500T plc. Do we have some plc instructions to read the actual angle of all the axis at the...
792
