read S120 axis angle instantly
Kataeb
Jan 2007
www.livelovelebanon.com
636
We have several S120 1FK7 axis controlled by an S7-1500T plc.
Do we have some plc instructions to read the actual angle of all the axis at the same point in time? (Axis1.ActualPosition, Axis2.ActualPosition, ...)
No
I recall an r value ( in S120) for the motor angle but in the TO I don’t think so
Are you doing modulo?
Can you calculate it?
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
161
Is there a way to use the FAL instruction to do +=2 instead of +=1? I have an array that is organized with alternating "data" and "flag" values...
127
Hi everyone i have a customer, who wants to show an alarm on the machine, if the I/O forces are enabled and set, on at ControlLogix L81E with...
263
Hi Iam using monitouch hmi(V9 soft) with omron plc cj2m (CX programmer). In this I want to read a data from hmi to plc. The data was like...
103
Hi everyone. Quick questions. On UnityPro, I want to open and quickly read tags from a .STA files witouth opening the program. I have 30 plc...
151
