Sqare D SY-MAX software question
fredjohns
Dec 2008
Pennsylvania
119
I am trying to run the SFW375 software so I can copy the PLC programs running in some old SY-MAX PLC's we got in from one of our companies that closed. The software disk contains the following files on it:
SFW375.EXE
SFW.SEC
AUTOEXE.SQD
AUTO.SQD
I am trying to run the program on an old PC that was running windows 95. I booted the PC in the DOS mode and typed in:
SFW375 and got the following error:
LOADING SECURITY PASSWORDS
LOADING PARAMETERS....
ERROR-UNABLE TO INITALIZE ASYNCH
If anyone has any suggestions and what I need to do to succecfully run the SFW375 program, your help would be greatly appreciated.
Fred Johns
Day Timer, Inc.
www.daytimer.com
SYMATE PLUS for Square D PLC
I have Symate Plus ver 2.06 DOS software for Square D PLCs.
It runs fine on Windows NT. We used it on PLC Model 650.
Worked really well.
I think SFW375 was the multi-site license version, of SFW374, that required a security key to be installed on the printer port.
Yes, I had heard that the SFW374 required the security key but the SFW375 did not. Has anyone used the SWF375 software and are there just 4 files that make it up or is there a second disk that I might be missing
Worked really well.
Do you know if the symate plus will work on the model 500's and is that software still available and what is the cost of it. The SFW374 and SFW375 is no longer availble from Schnider (Square D)
Yes, it will work on the Model 500's, Sy/Mate Plus (SFW47x) replaced the older SFW37x family of software around 1990. Sy/Mate Plus is also no longer available from Schneider Electric (since maybe 2000). There are Windows based versions available for the Sy/Max family.
The Sy/Max Model 500 PLC was obsoleted in the early 1990's.
155
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
233
Square-D Symax SFI-324 I have used the SFI-510 card for many projects, but I came across a SFI-324. Does anyone have ant tech info on it?
87
Hi, I am looking for some help with a GE Fanuc Versa Max Micro Controller model IC200UDR001-BF connected to a Quickpanel mini display...
166
Hi, The VersaMax PLC suddenly stop running (no LED on run function) so I'm trying to upload the program. The HMI connected to it says "Host...
144
