SQL Connection Path for FactoryTalk v10?
Apr 2018
Lincoln
Hi All,
I've managed to break my SQL server (v17) connection on an FT SE project. The first version of project I had on the PC worked just fine, I could view live PLC alarms and popup my historic alarm page and see the alarms stored in the SQL database. Since then I have added a later version of my project which was setup to run on a different PC. I can still see the SQL server data in the historic alarms popup but it is no longer logging alarm data from the current project as they come and go.
If I open the SQL server management app I can navigate down to my database and the name matches to that which the historic alarms page in FT is pointing at (not a surprise as it shows me the SQL data in FT runtime!).
How do I make FT write its alarm data to my SQL database? Is it a path set in the FT project or a path set in the SQL database.
I should point out that I had to rename the project, so I suspect that is the route of the problem!
Hi, We are doing a project in FactoryTalk View with Database connected to SQL via Connections available within the FactoryTalk View Project. Is...
1,597
Hi All, I'm having no luck with some development I've just started. I'm deploying a new roll-out of a factory Talk View Distributed system...
2,690
I have an PLC and HMI & SQL Server sitting on an isolated network (on Premis) and I would like to securely connect this to AZURE Cloud with out...
3,186
Goodevening all... I have a Redlion PTV and Graphite with built in webserver... I can create the simple default.htm page... drag in tags to...
1,912
I'm unable to get tag values and SQL database table values in VBA editor. Anybody please help me with this problem.
1,909
