SQL Server and WinCC
Eng.Abdo
Feb 2010
Saudia
64
Dear All
i have a group of Rectangle in WinCC which have different tags and similar values. i want to modify these group values again by using SQL Server. in which i create a table in SQL Server Database and connected to WinCC project and update these values in WinCC with out changing them one by one.
how / where i can set the ODBC in WinCC in order to do so?
is there any additional Add On for WinCC to do so.
is there any other recommended solution to keep same tag for the group of object and change the values at once.
i am using WinCC V7 SP3 and SQL Server 2005
:confused:
please advise
Hi all, I'm trying to connect WinCC Pro to SQL server through OBDC. Everything is okie, I'm able to transfer number, DateTime and even a direct...
1,448
I am new to WinCC and have limited experience with SQL servers and databases, but I have been presented with a problem with the overwriting of...
1,310
Kindly, while trying to install Siemens Pcs7 Wincc v6, we got a message that "SQL Server 2000 Service Pack 3a" need to be installed from a CD...
1,347
I'm trying to connect Wincc Flexible 2008 Advanced into SQL Server 2005 via script. For the test I made a db in the SQL as db_kalup and created a...
7,258
Hi all, I have installed both WinCC and Wonderware in my system and its respective database with it. but i am facing some problem in opening a...
5,366
