stand alone drive with encoder
sweetjohnny
Feb 2012
Iowa
55
i am looking for a stand alone freq drive with encoder, preferably allen-bradley. What i am trying to accomplish is reading the speed of another conveyor via an encoder and tell the freq drive (another conveyor) how fast to go. anyone done this before, if so what did you use?
As far as i know I´ve never seen an encoder used as an input to control speed of a drive. You can try using a frequency/voltage converter (encoder as a frequency generator) and use dc voltage as input to control speed of another drive. Even easier try using dc output from one drive as speed control for the other drive.
Can be done - However you will have to use the more expensive drive (eg powerflex 700 not a powerflex 40)
a large number of drives have a frequency input - this is a high speed pulse that is used by the drive to determine its reference speed
Better is to use a drive that has an encoder option - this encoder can be used as the reference speed for that drive.
Eg pf750
Or you can use something like this with very cheap drives:
http://usdigital.com/products/etach2
Hi there, I need to know how I can make a stand alone run time SCADA application in FTV to run it like an EXE file. Is it possible at all and...
20
5,341
Hi Guys, I'm making a selection for emerson's RTU, after going thru their site, I'm yet not too clear on one to select. Please if you have used...
2,271
I need to convert a Stand Alone application to a Modern, but I will not change the version of the intouch, so Intouch does not ask me the question...
3,296
Hello, I would like to ask for help in solving my problem. I need to move application created in InTouch Stand Alone to Archestra IDE. I'm...
2,876
Following on from the recent thread about using a PLC for furnace control, this has me thinking about a potential future project. I have just...
5,037
