Problem convert Intouch stand alone to Modern
Alexandresr
Sep 2017
Minas Gerais
I need to convert a Stand Alone application to a Modern, but I will not change the version of the intouch, so Intouch does not ask me the question for application migration and the question to upgrade to morden. Can you upgrade from Stand Alone to Modern in any other way?
to understand better, the step of the image below does not appear for me anymore:
https://www.mediafire.com/file/w2xyj33csjo6in0/aaa.png
I am in the 2014 R2 version, I do not intend to change version.
In intouch 2014R2 there are 2 types of applications, Stand Alone, and modern. In modern, there is a possibility to use the features of Archestra Graphics.
https://knowledge.insourcess.com/Wo...lone_to_Modern_Application_in_InTouch_2014_R2
This Technote above teaches you how to do the procedure I want, but in this technote I would need to be changing the Intouch version, and in my case I will not change the version.
You Need to click tools, find applications and browse to the folder you just converted. or check you log files in the system management console for a import error.
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
20
334
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
43
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
187
Hi, I am having a challenge installing a new drive ACS355-03E-44A0-4 as it keeps on displaying Fault code F00018 even when the load is not...
138
I have an issue on my vessel, we have water tight door system created in China, company is no longer operating. We have 7 doors each with their...
154
