Stand alone real time clock
khanz
Mar 2008
Sharjah
36
Hi all,
Is there any stand alone real time clock module available in the market, which has a minimum of 4 relay output. Thanks in advance.
I ran across a building controls controller today, a Honeywell XL50 or Excel 50(?) It had a date/time calendar, what I'd call a 'real time clock' with a number of I/O points, but I didn't read it real close, so I'm not sure if it had 4 relay outputs or not.
The HVAC or building controls market probably has packaged stuff like a what you describe.
Dan
As mentioned - most programmable relays have this function. Also Omron make a unit called the H5S which is available as a weekly or yearly time clock (2 or 4 outputs). Another brand I have come across is THEBEN which is quite cost effective and they have heaps of different models.
Hi there, I need to know how I can make a stand alone run time SCADA application in FTV to run it like an EXE file. Is it possible at all and...
20
5,338
Hi Guys, I'm making a selection for emerson's RTU, after going thru their site, I'm yet not too clear on one to select. Please if you have used...
2,270
I need to convert a Stand Alone application to a Modern, but I will not change the version of the intouch, so Intouch does not ask me the question...
3,290
Hello, I would like to ask for help in solving my problem. I need to move application created in InTouch Stand Alone to Archestra IDE. I'm...
2,873
Following on from the recent thread about using a PLC for furnace control, this has me thinking about a potential future project. I have just...
5,028
