Start Different Conveyor Using Timer
kasongomoma
Dec 2005
augusta,GA
Can someone help me to write a plc SLC500 program :
THE CONVEYOR NEED TO BE ON FOR ALL CYCLE TO CHECK TIRES OR MAKE
THIS TIRE INSPECTION PROCESS
-START_Push Button.
if start
turn green LED ON
-STOP PB
turn red LED ON
-If start, INCLINE CONVEYOR ON>>> OUTPUT 1
-wait (TON) ...> OUTPUT 1/DN
-CENTER CONVEYOR ON >>>> OUTPUT 2
-wait (TON)....> OUTPUT 2/DN
-BCODE CONVEYOR ON >>>> OUTPUT 3
-wait TON)....> OUTPUT 3/DN
-VISION CONVEYOR ON>>>> OUTPUT 4
-wait (TON) ....> OUTPUT 4/DN
- INSERT A ROUTINE PROGRAM CALL X-RAY
- ACCUMULATOR CONVEYOR
- INSPECTION CONVEYOR
- TAKE AWAY CONVEYOR
- REJECT CONVEYOR
-LOADER CONVEYOR ON >>> OUTPUT 5
You should also explain the process a little more. It appears that you want to use timers instead of sensing product. If this is the case, my experience tells me that you will eventually run into problems as the machine physical condition changes.
281
How to fix if appears code “$115 plc-restart running” on the screen OP17
250
Hello everyone, I'm new here. First of all I just want to say that you guys are very knowledgeable and reading your posts on here has saved my...
176
can anyone has a good program to learn plc programming online. i have the basic looking into improve my skills thanks
146
Hi guys! I'm working in Studio 5000 and have a bunch of armorstarts there (+- 40). I need to set up parameters for each of them, mostly just same...
96
