Starting 6 pumps based on their running hour
Augastya
Mar 2022
Bangalore
We have 6 pumps for which we calculated running hours from run feedback. We need to start these pumps based on demand in auto sequence for a day. I.e. the pump with least run hours will get priority 1 and with highest should get 6. If any pump fails to start, next pump should take tha the priority. Also sequence set should not change for a dayi if pumps are not failing to start
How this can be done in plc structure text or in fbd
Welcome to the PLCTalk forum community !
This sounds like a homework question for a PLC class. It is policy here not to answer those questions until the student has shown some of their work.
Please post some information about which model of controller you are using, and an example of how you have tried to solve the problem so far.
I m using ABB plc, I did through min and max function. And then compared with each run hour, this way which will be on first priority and which will be on last, is coming, but I m struggling to give intermediate priorities
Hi, I am attempting to turn on an output for one second, every thirty seconds, but am having some trouble. I have a XIC with S:1/15 (first pass)...
600
Rather new to structured text. I'm trying to edit a machine so that it will reinitialize with some push buttons held in for 10 seconds. Pushing...
2,755
Hi Guys, I'm using an ABL33ER with Panelview 600. I have datalogging running on the HMI using the view studio datalog model on startup of the...
1,151
Hello guys, I have windows 10 on virtualbox guests and not on the host. On a windows 10 guest I have TIA Selection tool V2022.06. When I...
1,519
Hi This message popped up when I created a new hard disk (image) (TwinCat IO Server. TwinCat is not starting because of an invalid device...
1,560
