Step 7 Debugging Functions Always Active
Jun 2007
Oxford, UK
163
Hi All,
Once again it has been a while...
I am having a problem with a S7-414F-3 PN/DP CPU. Initially all was fine during the initial commissioning but now I have been running the system for a few weeks through setup and now when I download (the CPU is no longer being powered down at end of play, it was before) the step 7 gives me the warning that debugging functions are active. This is even if I restart my laptop, restart step 7, turn off all other PCs on the network, restart the switch I am using to connect.
Going online via TCP/IP on wireless through a Belkin router on one of the front ports on the CPU. Step 7 version 5.5 SP4.
The only thing that seems to fix it is a power cycle of the CPU. Not sure if it is related to the safety program as I can also no longer download the safety program, but this is likely because debugging functions are active.
Anyone come across this before? Starting to be a little annoying.
B
Hello guys, I have uploaded a program from S7-300 PLC and of course, all symbolic names and variables are lost (I think that is a feature of...
1,923
Hello, I need help with debugging step7 I want debug a program in step7 with first engineer debugging FB1 to FB50 second engineer debugging FB60...
5,284
I am having a step7 v5.4 program where the blocks are encrypted and locked. And the manufacturer is stopped the support. Is there any ways to...
214
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
267
HI! HOW COULD I OBTAIN THE NAMES OF THE STEPS OF A ROUTINE IN SFC LANGUAGE IN STUDIO5000? Or is there a system variable that gives me those...
359
