Step7 DataBlock with STAT, not Symbols
RipSkater
Jan 2015
Wisconsing
My Step7 program has several Data Blocks built from UDT structures that no longer show the symbol names from the original UDT, just STAT.
How do I restore the Symbol names into the data blocks? I've already done a recompile with the Address Priority set to Absolute, and then for 'For All Access' without success.
Hi all. I wan't to copy a string message(160 characters) in to a Datablock from wich a SMS message(also 160 characters) is sent. I've tryed to...
6,924
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
161
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
156
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
146
Hi all, I am trying to convert RSLogix 5000 program to Step7. I need to bit shift left my array of double integers for tracking the product on...
528
