Step7 DB time stamp conflict
Pandiani
Apr 2005
Tz
718
Hello guys,
during examining of a PLC program I came accross to FB with red colored name of its DB. This is usually caused by making changes in the structure of FB. Now, since I didn't make any changes ,is there any way I can compare it with original structure ?I suspect that original structure is downloaded to PLC, I want to see what are the changes or when they were created.
is there any free trial version available for step7 professional and wincc comfort v17. i searched and downloaded TRIAL Download STEP 7...
74
Hello. I need your help. I work at STEP7. There are two CPU 317-2 PN/DP controllers (317-2EK14-0AB0), working on PROFIBUS, as Master (CPU_1) and...
183
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
180
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
163
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
162
