Step7, Diagnostick error.
kire
Apr 2014
UK
55
Hello,
I have some question regardering step7 diagnostick buffer.
Please see attached screenshoot, why does I have error on the
CPU when I`dont have any event error? the last is really old... ???
It says you have an FC, or function, that is not loaded. Your program is trying to call a function that has not been downloaded to the processor.
The details on event window say it is FC1004. If you have it in your Blocks folder, try selecting it and downloading it.
Download FC1004. If it is not in your blocks folder, try to see where it is called.
Right click blocks and check consistency is usually the fastest way.
You can send me your program if you'dd like me to check it for you
Are you in a position whereby you can stop and re-start the CPU to verify that the diagnostic buffer is updating?
Have you looked at the h/w config online to see if this gives you any clues?
Hello,
Thank you for your input, I can see you are thinking same ways that I have...
The clock is correct in the CPU so the FC load error is old...
FC is exist online.
I`m not abel to restart the CPU....
So we think the error will disepar when we restart the CPU?
is there any free trial version available for step7 professional and wincc comfort v17. i searched and downloaded TRIAL Download STEP 7...
65
Hello. I need your help. I work at STEP7. There are two CPU 317-2 PN/DP controllers (317-2EK14-0AB0), working on PROFIBUS, as Master (CPU_1) and...
175
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
180
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
161
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
162
