Step7 Duty/Standby block
ged
Jun 2010
Sydney
18
Hello, I posted a thread and it did not seem to go through so I will try again..
I am looking for sample code for a Duty/Standby block for a pump application. I have an existing motor block that feeds into a PID FB41 block. A duty pump is being added. I am duplicating the existing code but now need to control the motor blocks with a duty/Standby block. I would appreciate any pointers. Changeover is based on Runtime, Operator manual select, stop/start or if the Duty pump is not available, defaults to the Standby pump
Thank you for any input.. Ged
And where is your contribution? You want pointers, but what kind of pointers? Do you need help with the code or with the operation?
Hi
Are the manual controls 'outside the plc' ie hardwired, in case of plc failure?
With regards to your program, get a sheet of paper and write a list of what you know (inputs etc) and what you want to do (outputs etc)
Write down all intrlocks etc thst you know about, plusa few you dont :)
Review your existing code and then graft in your extra code.
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
161
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
156
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
146
Hi all, I am trying to convert RSLogix 5000 program to Step7. I need to bit shift left my array of double integers for tracking the product on...
528
I have a word in some DB which I want to load to AR1 and use as a pointer. In order to do this I need to write L DBxy.DBW xy SLD 3 LAR1 I...
550
