Step7: Global Data between PLCs
S7PP
Sep 2010
Toronto
134
Hi Experts, I'm trying to connected 2 PLCs through Ethernet and define Global Data between them. Is it possible? Why the "Define Global Data" item is always grey?
The IP address for the PLCs are 181.107.22.46 and 181.107.22.47.
Please help~~
Really? Then what should I do if I want to transfer data between PLCs when I connect them on Ethernet?
how to get there?
Hi Jesper, I'm trying to learn this BSEND and BRCV function, but I'm able to find the "properties - S7 connection" page. would you tell me how to open it?
sorry, I'm a dummy at this point.
S7PP
It is in NetPro.
When you have started to make a connection, this dialog will appear.
If the connection is already created, then click on it in NetPro (in the list of connections when a CPU is selected), and the dialog will appear.
It's not appear.......I almost cry.....see my picture, I clicked everywhere, but still not showing me the dialog like that. Wuuuuuuuuuuu
Hopefully someone can validate my thoughts on the following: I'm looking at a proposed program design for a line which will be with us early next...
7,071
Hi! I am new to Siemens Step7 and are hoping for some little starthelp, Thanks. I have made some FB, but would like to know if it is possible...
7,531
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
161
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
156
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
146
