STEP7 hardwareconfiguration
kurosawa
Aug 2004
I know that if the module-number on your card is not the same as that module has in the HW-catalogue I need to install an new service pack or 'Upload' the new hardware.
But today somebody asked me if it is possible that a module with a different order-number then what I have in the HW-catalugue still will work. Meaning that for example I still can read real-world inputs.
I would like to test it but I only work with cpu312C's onboard I/O and I have no spare parts to test it. So if somebody can let me know I would be greatfull.
In case if you have newer module but in HW config older version is defined, it will work in most cases. With restriction - you will not have possibilities of newer version.
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
146
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
143
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
138
Hi all, I am trying to convert RSLogix 5000 program to Step7. I need to bit shift left my array of double integers for tracking the product on...
525
I have a word in some DB which I want to load to AR1 and use as a pointer. In order to do this I need to write L DBxy.DBW xy SLD 3 LAR1 I...
542
